Posted by janicholson on November 02, 2011 at 17:07:39 from (96.24.99.126):
In Reply to: Amp meter posted by slifnom on November 02, 2011 at 15:40:35:
A new voltage regulator should be OK. The issue is needing one assessmant before condeming the VR. With a good volt meter (Digital is good only if it is capable of reading well in noisy old systems, most do not) The voltage should be 7 to 7.2 volts when the meter leads are across the battery at 3/4 throttle. If this is the case, all is well. These systems do not charge at idle. At 1/2 throttle it will pickup and charge. Less, and it will go to a little below zero on the gauge due to coil draw. The tractors were made to run making power all day. If it does not make that voltage, and you have charged the battery and it is still low at fast engine speeds, take the regulator back. Good luck. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
