Posted by pete 23 on November 02, 2011 at 17:54:26 from (74.32.238.142):
In Reply to: Re: shutting of an A posted by Charlie M on November 02, 2011 at 12:53:15:
You are correct, you should be able to kill engine by grounding the terminal at magneto. The thing that puzzles me is that the wire from the points runs to the condensor and that is where the shorting wire is hooked to, so how it can run well if that wire is not good or not hooked up is a good question. At any rate, your kill wire to switch has to be making contact with the threads on end of condensor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
