Re: Hydraulic Problem
Posted by Mike1972chev on November 02, 2011 at 18:38:55 from (99.50.226.81):
In Reply to: Hydraulic Problem posted by Ed Bouws on November 02, 2011 at 18:01:58:
When you say"vent cap",are you meaning the fill cap on your belly pump reservoir????
Do you have your hydraulic return hose plumbed into the fill tube on your belly pump reservoir???
