Re: 14.9-38 Tires
Posted by mkirsch on November 03, 2011 at 05:58:22 from (64.80.110.75):
In Reply to: 14.9-38 Tires posted by IAtractorKid on November 02, 2011 at 16:30:50:
Finding "decent used" anything related to tires and rims is a challenge.
I think the tires will be fine on the 11" rims. Nothing disastrous will happen, for sure.
Worst case you can put them on, continue to look for wider rims, then transfer to the wider rims if/when you ever do find any.
