Re: H Transmssion Oil Seal - High Hopes
Posted by David Goode on November 03, 2011 at 08:12:26 from (209.234.70.196):
In Reply to: H Transmssion Oil Seal - High Hopes posted by George Rausch on November 03, 2011 at 04:50:20:
When I did the front Seals on my Super M I spent at LEAST three days working with that Damn couple; I too found it doesn"t want to "slide off" as people say it should. What I ended up doing was heating it with a propane torch, then using a BFH and pry-bar to knock it off. Then After the coupler was off I took a brake-cylinder hone and cleaned up the inside hole and used Emery cloth on the actual shaft. Keep working on it, it should work its way off.
