Posted by gene bender on November 03, 2011 at 13:19:02 from (67.55.226.244):
In Reply to: Replacing seals on B posted by freefour on November 03, 2011 at 06:16:07:
Ive replace many of them and a cherry picker is handy for the final drives. The left side you will need to remove the brake drum as the diff shaft slides out the hole in the top of the final drive where the little plate is with the four bolts. Drives side the drum is at the far end and also needs to be removed to let the diff shaft go out thru the hole. Seals in the tranny are easy also just get the shims lined up so you can bolt the housing holding the seal back after replacing the seal.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
