Check the governor spring to make sure it's not worn out or the holes are not wallered out causing the hesitation. There is no adjustment to the governor itself besides setting max RPMs. If it is sticky, then removal and a good cleaning might be in order. There is a small needle bearing on the output shaft, and it has a woodruff key that often develops play in groove. The support arm that comes off the front of the block is another place to look that causes resistance.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
