Your friend's 1978 Windsor would from the factory, have had induction hardened exhaust valve seats - designed to operate with non-lead fuel. Ford converted to hardened seats on the Cleveland, Lima and Windsor engine production lines in the early part of 1970. I dug out my copy of an article in Metal Progress magazine, 1973 issue, which detailed the hardening process.
Also included in the article is a graph of Fords durability tests (high speed and load) showing an exhaust valve seat recession of 0.080" in 10,000 miles with conventional seat material hardness and non lead fuel - hence the justification for hardened seats. The same test conducted out to 50,000 miles confirmed the hardened seats on non-leaded fuel had less exhaust valve seat recession than the conventional seats on leaded fuel. Exhaust valve seat recession is due to locailized welding at asperities due to high unit loading. The lead in the fuel provided a thin protective film that prevented the welding and resultant wear. The hardened seat material works without the need for lead since the hardened cast iron (martensitic structure) is much stronger and better able to resist the welding/wear.
Several things to note here: 1) these were cast iron engines and did not use separate valve seat inserts, 2) the durability test was high speed and load designed to turn on the problem, 3) Engines that do not operate at high speed and load as in tractor engines, are unlikely to be subject to significant exhaust valve seat recession, 4) engines using separate valve seat inserts may not be subject to exhaust valve seat recession depending on the material used.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
