Re: small C update
Posted by Ron-MO on November 03, 2011 at 18:46:02 from (69.55.148.114):
In Reply to: Re: small C update posted by soundguy on November 03, 2011 at 17:54:43:
You are correct on the square IH decal top center of the grille. Should only have one phillips head screw holding it on.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
