Posted by glennster on November 04, 2011 at 06:09:40 from (76.217.102.189):
In Reply to: Re: H Charging system posted by Janicholson on November 03, 2011 at 18:40:31:
yup jim, thats the one!!! that dang genny drove me nutz trying to get that h to charge. had it back to the rebuilder a couple times, it would bench test great, regulator worked great, wiring harness was correct, but as soon as everything was hooked up to the tractor .....no charge. thats when you walked me thru testing the genny installed on the tractor and found the short where the either the arm or field bolt was shorting on the case because the insulator had cracked on the inside of the genny case, when the wire was attached and tightened down, it would short and cause no charge condition. thanks...glenn
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
