Do you know if it is leaking out of the engine, or is it the transmission front seal. I bet it's the transmission seal. There is no place for the leaking transmission seal to drain except out of the clutch housing near the engine. Splitting a Cub is pretty easy since it's not that heavy. If you know it's the transmission front seal, split at the front of the transmission, not the engine. If it's the transmission seal that is leaking, replace the front bearing of the transmission as well as the seal. On the Cub there is no coupling in the drive shaft, so you have to deal with that. The shaft goes all the way from the transmission into the clutch plate with no coupling. No issue there if you split at the engine, but if at the transmission, you have to roll the two parts farther apart and it's a little tricky getting the shaft lined up to go back in the clutch plate.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
