Re: A gen belt replace
Posted by gene bender on November 04, 2011 at 17:59:29 from (67.55.226.244):
In Reply to: A gen belt replace posted by PeteEllis on November 04, 2011 at 17:31:41:
You dont need to remove the water pump but you will need to remove the belt that runs it. If you get the fan assy loose and down as far as it goes removing the belt from the water pump you should be able to install the new gen belt. Have fun your knuckles will have some sore spots when you are done. Good luck and have fun.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
