Re: 766 tire question
Posted by janicholson on November 04, 2011 at 18:09:47 from (96.24.99.126):
In Reply to: 766 tire question posted by kennell on November 04, 2011 at 16:03:12:
Other than the traction advantage of the radial, no. In a car/truck the handling and differential wear is an issue. The tractor will not care. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
