Re: Alternator posts 1 and 2
Posted by equeen on November 04, 2011 at 21:17:00 from (209.102.248.236):
In Reply to: Alternator posts 1 and 2 posted by equeen on November 04, 2011 at 20:24:37:
Okay, more details...
Rusty ole Farmall Super A that I'm trying to repair/get running - not restore.
Someone converted to 12v alternator system and the wiring, what's left of it, is as follows:
Negative coil to distributor
Positive coil to "resistor" (white ceramic thingy)mounted with coil bracket.
"Jumper wire from left post on "resistor" to right post on "resistor".
Wire (cut) from right post of resistor apparently went to right small post of solenoid.
Alternator:
Ground post wired to ground
Post 1 wire cut
Post 2 jumpered to "bat" post.
Bat post wire of alternator to Ammeter
Jumper wire from same side of ammeter to fuse?
Wire from other side of ammeter to battery cable post of solenoid.
