Re: Tank heater on Farmall H or headbolt heater.
Posted by CoopertownBob on November 04, 2011 at 22:16:31 from (74.51.5.116):
In Reply to: Tank heater on Farmall H or headbolt heater. posted by Janicholson on November 04, 2011 at 11:42:40:
Or even better install the correct amount of anti-freeze solution to avoid the trouble, and maybe keep a drop-light behind the radiator at night if it gets really cold. Or you could do like a neighbor of mine does and just drain the water jacket completely every evening, then refill it with hot water from the house in the morning. On REALLY cold mornings, he boils the water first. The drop light trick will also work to keep it unfrozen during lunch time as well if it is good and hot when parked.
