Posted by Harold Hubbard on November 05, 2011 at 04:07:46 from (205.209.16.24):
In Reply to: Brake seals, Farmall C posted by Andy in Ripon on November 04, 2011 at 15:56:46:
I see you have all the bolts removed from that shaft housing. DON'T try to pull it if you haven't removed the bull gear from inside the case. The housing is notched out and fits over the bull gear, if you force it you WILL break it.
You can beat the old seal to death and pry it out without any further dis assembly. The original seals were double thickness with two lips. The new seal is probably thinner, and there is probably room in the housing for two of them. You need to be sure that the drum is not rough or grooved where the seal rides in it. If it is smooth, but grooved, use one thin seal and try to install it so that it does not ride in the groove.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
