GOOD CATCH, I cant hardly read what it says on the coil?? But if its a 12 volt coil and that white wire indeed just shorts out the ballast (that works as no ballast should be used if? its a true 12 volt coil), the only other wire that blue/green must be the feed wire down from the Ignition Switch.
If its a true 12 volt coil he needs to throw that rats nest mess and ballast all away then where the ign wire (blue/green) attaches to the coil input (NOT to distributor) terminal he needs to attach another wire and a 10 ohm resistor (or diode) then down to No 1 on the Alternator.
So simple if we were there but harder to describe in words if hes not good with electricity.....
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
