Re: 1066 clutch problems
Posted by pete 23 on November 05, 2011 at 10:52:32 from (74.32.238.142):
In Reply to: 1066 clutch problems posted by TWL on November 05, 2011 at 09:04:03:
Sounds like you need to adjust the dump valve as it does the same things a 560 does only with hydraulic pressure. If the red light for trans oil pressure works, adjust so light just goes out when engaging clutch before tractor starts to move. Or drive it up an incline and adjust so tractor will roll freely backwards with clutch fully released but will not roll back just a tad before clutch starts pulling tractor. May even be correct the way it is from your description.
