Posted by Haas on November 05, 2011 at 15:43:29 from (166.248.72.218):
In Reply to: H Brake Seal Problem posted by WI Dave on November 05, 2011 at 15:05:40:
I think the damaged part is part of the bearing. The parts diagram does not show anything else that I can see. To replace the bearing, the bull pinion bearing cage has to come out. That"s the flange and cage that holds the bull pinion bearings and shaft/gear. To get that out, you have to open the transmission (some say you can do it through the PTO opening) and take the bull gear off the axle and drop it down so it"s not in mesh with the pinion gear. When in mesh, the bull gear blocks the cage and it can"t come out. The pinion shaft and bearings come out to the inside. So you have to pull the housing, bearings and pinion shaft as a unit and then you can remove the shaft and bearings. All that said, if you think the bearing is not damaged (besides the retainer ring, I"d rotate things and see that all runs smoothly with no noise and put her back together. It"ll be a big job to replace the bearing.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
