Re: not fring on all four cylinders
Posted by TomH in PA on November 05, 2011 at 16:32:34 from (184.5.168.77):
In Reply to: not fring on all four cylinders posted by Gary Sedlacek on November 05, 2011 at 14:24:13:
Sounds like it's way out of time, they will run like that.
Find top dead center on the compression stroke of #1 by taking the plugs out and feeling for compression on #1 with your thumb as you rotate the fan blade by hand. Then look at the points and rotor; points should be just opening and rotor should be near #1 wire. If not, rotate the distributor until the points are starting to open, then arrange the wires so firing order is right.
