Posted by Jimb2 on November 05, 2011 at 17:32:36 from (173.35.57.64):
In Reply to: B-414 Diesel posted by Jake B-414 on November 05, 2011 at 12:13:06:
Hi Jake, had a couple problems where a B-414 Diesel stopped like it was out of fuel. 1) Key came out of shut off control lever on top of injection pump. 2) Ice formed on top of primary fuel filter. 3) Foreign material clogged the filter on the input fuel port of the injection pump. This required removing injection pump and taking to a Diesel Injection pump repair shop.
Have you bled the fuel system, including opening the bleed screws on the injection pump? Also after bleeding the fuel system then loosen a nut on one of the injector lines and then try starting the engine. Be CAREFUL with the high pressure Diesel fuel from the injector lines.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
