Posted by equeen on November 06, 2011 at 05:21:11 from (209.102.248.236):
Yep, I'm an elementary electrical(Pre-K) sort of guy; but here are the questions:
1. IH "Out to run", "In to stop" ignition switch has two wiring terminals. I see no markings identifying either terminal in any way. Thus, is it proper to wire from the ammeter to either ignition switch terminal, then all other wires to the other terminal?
2. I've seen a wiring diagram of a fuse in the wire between "BAT" on alternator to the ammeter. Is this necessary/helpful? If so, what type of fuse/holder?
3. Alternator #1 spade switch wire to ignition. Wiring options appear to include somewhere along the length of the wire: A filament style marker lamp bulb, or A 15 ohm resistor, or A 3 amp 50 volt PIV diode
Of course I could be confused with the above, but my question remains...... What is the purpose of something in this stretch of wire?
4. And, while I'm at it... how do I properly wire the original Delco Remey light switch (photo above)on the Farmall?
Term 1... Term 2... Term 3... (Is the #3 post on the L shaped piece of metal with 2 screws in it including the screw for #1 post?)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
