Re: Changing farmall m governor
Posted by charlie M on November 06, 2011 at 05:27:56 from (74.34.200.218):
In Reply to: Changing farmall m governor posted by Bbbe2011minnesota2011 on November 05, 2011 at 20:04:48:
That's about it - if I remember correctly there is a 4th bolt on the carburetor side near the block that has to be removed.You'll need a gasket also. Make sure you get the connection to the carb right or your tractor will run full bore with no throttle control.
