Re: WD9 Motor
Posted by WOpp on November 06, 2011 at 08:22:25 from (75.221.60.198):
In Reply to: WD9 Motor posted by WD9 Man on November 05, 2011 at 05:28:43:
Old style 335's as you call them had sleeves that were flush with top of block and need a head gasket that sets on the top of sleave to keep it from moving. The new style diesel 335's use a sleave that is .004's taller than block, requiring a head gasket that fits around the sleave. This is only gasket I have been able to buy for mine. The heads have had many up dates through the years, All should fit any 335 or 350 engine.
