Re: 450 bearings
Posted by T_Bone on August 27, 2000 at 21:21:44 from (207.254.53.45):
In Reply to: 450 bearings posted by Steve on August 27, 2000 at 20:31:13:
Hello Steve,
You also loose oil pressure from the cam bearings being worn. Could be piston knock too from worn wrist pin bushings. You can aslo lapp the valves your self providing the rest of the head looks ok.
Why take the time to do a half job when all it takes is a couple hundred more to go first class, then it'll last you a life time. You will smile in the long run!
T_Bone
Post A Followup
: Re: Re: 450 bearings
