Re: Broken WFE on 1940 m
Posted by Janicholson on November 06, 2011 at 08:40:17 from (96.24.99.126):
In Reply to: Broken WFE on 1940 m posted by E-manhunt on November 06, 2011 at 05:50:08:
Spindle is the vertical component including the wheel bearing shaft, it extends through the axle vertical tube and has a woodruf Key in the top, connecting to the steering knuckle arm.
THere are several axles that have been moubnted on M Farmalls, some from the factory and early with the linkage in front of the main axle tube (exposed to ramming things) and other brands and styles from many sources. Pictures will be needed to assess the brand.
Best guess is the woodruff Key if it has that feature. Jim
