Re: m throwout bearing fork
Posted by Maxx on November 06, 2011 at 10:52:59 from (204.12.175.113):
In Reply to: m throwout bearing fork posted by farmerkevin on November 06, 2011 at 10:15:14:
Easy repair if that is what broke.
Remove the spring from the fork.
There are 2 bolts on the fork that clamp down on 2 washers that sit in keyways on the shaft.
Pull shaft out of bell housing till you can slide off the fork.
You really need to see what's wrong first then the answers will be better.
third party image
This post was edited by Maxx at 10:55:28 11/06/11 2 times.
