Posted by Mr Farmall on November 06, 2011 at 12:35:43 from (69.141.81.182):
In Reply to: Super A Questions posted by Badger08 on October 31, 2011 at 18:20:23:
You may not have a cooling problem but a lean problem. Any vacuum leaks will cause the engine to run hotter than it should. A very common source of vac leaks are stripped main jet plug threads in the carb casting. Alot of the reman carbs use a steel plug that strips out the threads, it should be a brass one.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
