Re: 444 info needer
Posted by Janicholson on November 06, 2011 at 15:08:13 from (96.24.99.126):
In Reply to: 444 info needer posted by gutterman on November 06, 2011 at 06:38:19:
Diesels are that way. Some are more cold natured than others. The 444 is a fine tractor. It will likely need a block heater for use below freezing, and may need a an hour to 30 minutes on the heat above that. Good luck, Jim
