Re: pulling sleeves from F-20 block
Posted by Nebraska Cowman on November 06, 2011 at 17:58:56 from (66.252.115.26):
In Reply to: pulling sleeves from F-20 block posted by SDE on November 06, 2011 at 05:49:27:
5/8 rod is kinda spindly. It will stretch and absorb the pull. I'd use at least 3/4 As long as your disc fits the bottom you won't hurt anything. The factory puller is just a two sided affair and you have to make sure to get it started square or the bottom of the sleeve splits like a chicken. They pull hard. I tighten the nut down all I think it will stand, then go have a cup of coffee. Pretty soon it will start to come.
