Re: Poor luck continues
Posted by Paul from MI on November 06, 2011 at 18:06:31 from (204.106.241.145):
In Reply to: Poor luck continues posted by Chief 83 on November 06, 2011 at 16:58:25:
Does a voltmeter on the wire between the coil and dist. show fluctiation between voltage and ground as the engine is cranked. If not, you may need to clean a little oxidation off of the points. I usually use a dollar bill dragged between the points to clean off any oxidation from storage. There's something in the rice paper our money is printed on that make a graet point cleaner
