Posted by gbs on November 06, 2011 at 19:35:51 from (71.54.128.201):
In Reply to: Poor luck continues posted by Chief 83 on November 06, 2011 at 16:58:25:
sounds like your points are not making contact because of something coating the contact surfaces or you don't have a good connection with the points or points to ground, with a test light dist. cap removed points open test the wire where it connects to the points with the ign.switch on, it should light up, then turn the engine enough to close the points then retest it, should not light up ,if it does try cleaning the contacts, if after cleaning contacts if it still lights with points closed ,hook the test light wire led to a hot wire and test contact for proper ground, it will light any time it makes contact with a ground ,points base and base plate as well as dist should be a ground source,a common mistake made when hooking up the wires to the points one of the wire will get positioned wrong and short out the points, but you said you coil is hot on both sides that won't be the case if its shorted
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
