Re: 656 Farmall Hydraulics
Posted by pete 23 on November 06, 2011 at 19:52:09 from (74.32.238.142):
In Reply to: 656 Farmall Hydraulics posted by atkins52206 on November 06, 2011 at 17:56:11:
You have a few options here. Like other poster said, just add another valve, it bolts right along side of one you have. You will have to get a valve that is open on both sides though as the one you have most likely is closed on outside. It may have a cover plate on outside, depending on vintage of tractor. Or, you can mount a joy stick or double valve on the loader, route oil from your one valve you have and tie that valve back to hold it . Or, get a power beyond valve plate, mount that on your valve, again use a joy stick or double valve on loader. This will allow you to still use your original valve if needed for something else. Another option, electrical control valve hooked to your original valve. Lot of different choices.
