Re: 504 hydraulic pump question
Posted by pete 23 on November 06, 2011 at 20:00:20 from (74.32.238.142):
In Reply to: 504 hydraulic pump question posted by teachingscience on November 06, 2011 at 19:30:01:
No relief valve in pump. Flow divider valve assembly has relief valve for steering only. Main relief valve is located in aux valve mounting block. Do not plumb in ahead of that relief valve. You need to go through your aux valves or add a power beyond plate.
