Re: What is the J suffix on my Super M serial tag ?????
Posted by athol carr on November 07, 2011 at 00:11:16 from (115.188.3.223):
In Reply to: What is the J suffix on my Super M serial tag ????? posted by Mike1972chev on November 06, 2011 at 16:04:55:
The O-12 and other 12 series tractors of the 1930 had Rockford clutches. The Rockford clutch was the most common option in the Farmall A but Auburn was possible. My 1941 W-4 has a Rockford clutch
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
