Re: pulling sleeves from F-20 block
Posted by JRSutton on November 07, 2011 at 04:22:25 from (75.130.109.233):
In Reply to: pulling sleeves from F-20 block posted by SDE on November 06, 2011 at 05:49:27:
I'll add that you should but some grease on your threaded rod.
Obvious to some, but I've noticed a lot of people overlook that simple step.
Just makes it so much easier, and keeps the heat and distortion down to a minimum when you get real tight.
Drives me crazy seeing guys cranking a dry puller while it's squeaking and squealing in pain.
5/8 rod might be a little on the thin side, but if it's greased up good, it should do the trick.
