Re: Poor luck continues
Posted by Nebraska Cowman on November 07, 2011 at 04:58:44 from (66.252.115.26):
In Reply to: Poor luck continues posted by Chief 83 on November 06, 2011 at 16:58:25:
here's how to check a coil. disconnect the wires (you can do this with the coil off and in your hand) have the high tension wire in the tower. Hook a battery (or battery charger) positive to + and then touch the negative to the - side. When you release the connection it should throw a spark. What you are doing is replicating what the points do.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
