Re: what alternator?
Posted by Janicholson on November 07, 2011 at 08:51:13 from (199.17.6.77):
In Reply to: what alternator? posted by mike paulson on November 07, 2011 at 02:26:23:
Hooking that Nissan alternator is not one wire!
Run a 14 gauge wire from the S terminal to the big stud for the 10 gauge wire. This is about a 5 inch wire and terminal end for both ends.
Next run a wire from the L terminal to a 15 ohm 10 watt resistor (radio shack) then to the ignition switch if it has distributor ignition.
If it has a Mag ignition, Search for Janicholson Mag ignition in the search for box in Parts and pieces. Jim
