Re: Farmall 560 Tractor
Posted by Wardner on November 07, 2011 at 15:26:19 from (4.154.237.33):
In Reply to: Re: Farmall 560 Tractor posted by JAngel on November 07, 2011 at 12:13:35:
S = TA with 540 IPTO
Y = 12 GPM Hydra-Touch pump
CC= 3rd speed heavy tillage gear attachment
The preceding numbers (33925) are the serial number.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
