Re: 3 point to fast hitch adapter
Posted by RN on November 08, 2011 at 09:45:26 from (184.60.4.1):
In Reply to: 3 point to fast hitch adapter posted by Rex Simpkins on November 07, 2011 at 23:48:47:
Couple implement dealers in Iowa had the 3pt to fast hitch 2 point adapters for use with their implements- Landpride chopper was the one on disply with adapter mounted. The local IHC/Case/NH whatever it is now dealer had the same type adapter- a inverted U with adjustable top link at curve of U, lower mounts at tips and opposite side of tips had the 2 point prongs for insert into fast hitch. Another type I"m told is a triangle frame instead of inverted U and this design is supposed to be available as a set of plans for home building-- with builder taking his chances on liability if resold. RN
