Posted by Janicholson on November 08, 2011 at 10:08:43 from (199.17.6.77):
In Reply to: fixing a manifold posted by charlie M on November 08, 2011 at 09:33:48:
Backing the weld area inside with charcoal, or carbon (or a mild steel plate if it will not restrict flow) will allow thin metal to be brazed fairly easily. Welding with Ni rod (again with backing) is also possible. If the hole is on a flat area, a Stainless Steel washer can be bolted in place (possibly on inside and out) Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
