Re: Sediment bowl adapter
Posted by Haas on November 08, 2011 at 12:06:39 from (166.248.66.93):
In Reply to: Sediment bowl adapter posted by freefour on November 07, 2011 at 19:19:01:
The fuel line connection in the white metal part of the sediment bowl is most likely 1/8 inch pipe threads. So take out whatever came in that outlet with your new bowl. Then go to NAPA or a plumbing supply and get an adapter that goes from 1/8 inch male pipe threads to 5/16 compression tube fitting. Screw that into the 1/8 pipe threads on the bowl and then use the compression tube fitting to connect to the gas line. You may have to cut the end off the old tubing and put the ferrule on the tubing. If you don't care about making it look orginal, then get some 5/16 ID rubber gas line tubing and use a short piece of 5/16 copper tubing at the sediment bowl and slide the rubber tubing over that and install a clamp. Do the same at the carb end.
