Re: WD9 Motor
Posted by M Diesel on November 08, 2011 at 16:43:56 from (12.24.61.12):
In Reply to: WD9 Motor posted by mkirsch on November 05, 2011 at 05:28:43:
Fittings are different too, for those early Bosch equipped units.
There is a crankshaft change in the 335 somewhere as well. They went to bigger journals.
