3 position switch - original
Posted by equeen on November 08, 2011 at 18:55:42 from (209.102.248.236):
I have two subject switches from Farmall Super A tractors. These are Delco Remy and appear to be original with the tractors. Questions....
1. Will one of these switches work on a 1950 Farmall Cub with 6v generator and voltage regulator?
2. Will one of these switches work on a 1951 Super A with 12v alternator system?
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
