Re: Help Engine Seizing issue!
Posted by JRSutton on November 09, 2011 at 17:22:11 from (75.130.109.233):
In Reply to: Re: Help Engine Seizing issue! posted by mkirsch on November 09, 2011 at 15:34:41:
Connecting rod caps/bearings had to come off to get the pistons out.
Those really, really, should be kept in their original locations.
Mismatched connecting rod caps can be ugly - as well as mismatched old bearings.
Same applies to the crank mains - But was assuming the crank stayed in - but it is an assumption, so worth mentioning.
But still think it's most likely rings either aren't gapped right - or as somebody else said, carbon in the grooves.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
