Re: Help Engine Seizing issue!
Posted by dan cooley on November 10, 2011 at 13:15:02 from (72.227.91.45):
In Reply to: Re: Help Engine Seizing issue! posted by mkirsch on November 09, 2011 at 15:34:41:
i removed the oil pan, took the pistons out the bottom, are the bearings the sleeves that go between the crankshaft and the connecting rods? i just put them back on the way they were. i put new rings on and put the pistons back in through the top. it runs fine, starts right up but every other time i run it it seizes when i shut it off.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
