Re: decal placement on C
Posted by mkirsch on November 10, 2011 at 14:02:44 from (64.80.110.75):
In Reply to: decal placement on C posted by soundguy on November 10, 2011 at 05:41:29:
Use ODB on the light switch if you have a 3-position switch (i.e. 2 clicks).
Use LHDB on the light switch if you have a 4-position switch (i.e. 3 clicks).
