Posted by Janicholson on November 10, 2011 at 19:08:36 from (96.24.99.126):
In Reply to: model A wiring posted by merle t on November 10, 2011 at 14:12:26:
Assuming it is a Delco alternator, The following diagrams are all you need. The solenoid is wired with the following: Wire from Battery Positive to the Relay (solenoid) big terminal closest to the small terminal with an S near it. Wire from Amp gauge (10gauge) also hooks at that terminal. Wire from start (switch/button.Key S terminal) to the S terminal on Relay (12gauge). Wire from I terminal on relay to + marked coil side of the ballast resistor (12gauge). #0ga Wire, or copper conductor, from the Big relay terminal to the starter input terminal. Wire from the ignition switch to the ballast resistor other terminal not connected to coil. All others as in diagram attached. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
