Re: Cracked Block
Posted by gbs on November 10, 2011 at 19:21:48 from (71.54.128.54):
In Reply to: Cracked Block posted by Livin the Dream on November 10, 2011 at 06:04:41:
cheap fix if works ok if not then your not out much money,drain coolant clean crack by lightly grinding or use coarse sand paper to leave cleaned area rough then apply a good layer of JB weld according to directions,used this several times with good results last time was on a V-10 ford engine that a small hole suddenly started leaking coolant on the left head, tried two different block sealers with no luck, so instead of spending $$$$ to repair the aluminum head or replace it, cleaned it forced some of the putty thru the hole then covered it over hasn't leaked for 2 years cost under $5
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
