Re: H4 magneto problems/questions
Posted by SadFarmall on November 11, 2011 at 03:09:14 from (112.213.168.102):
In Reply to: H4 magneto problems/questions posted by Kippster on November 08, 2011 at 18:47:19:
Just had a similar dilemma with a Farmall M I would like to buy. If you have not already done so, undo the four screws which secure the magneto coil cover. Remove the cover, being careful not to lose the screws or the paper gasket. Check that the contact on the magneto coil is clean. Check that the spring contact inside the coil cover is clean. A greenish build-up can grow and reduce or eliminate spark, despite perfect points, condenser etc.
SadFarmall
